Hi All,
I've just rendered (through Share-Create Video File) an avi file to mpeg and Ulead has created two rendered files. The length of the project is one and a half hours long. The first rendered file is 3.99gb and the second is 1.26gb. Normally it would give me just the one rendered file. Have I missed something in my settings?
Thanks in advance for any help.
Rendering from AVI to MPEG created two files VS10+
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
What file system are you using with your hard drive (ie how is your hard disk formatted)? FAT32 or NTFS?
I am guessing that it is FAT32 and the maximum filesize is 4Gb and that is why you have two files.
John a
- ram: 2 GB
- sound_card: Intel GMA 950
Please click here -->
so that we can then view your system specifications.
If you are using Windows XP then I strongly recommend that you convert your hard drive to the NTFS system. It is reasonably quick and you will not have to re-install any of your software.
Converting your Hard Drive to NTFS
The external hard drive was formatted as FAT32. I use Windows XP Professional and after backing up the files converted it to NTFS as follows:
Start-Settings-Control Panel-Admin Tools-Computer Management-Disk Management-Right Click relevant Drive-Format
Everything is now ok and my project has been rendered as one file instead of two. Thanks for your replies.
