Hi -
Thanks so much for the detailed work flow and format guidance. I have just started with VS 10+ and succeeded in the first 2/3 of the workflow. I was able to get to the stage of having an .mpg file that I could burn to a DVD and which is playable within within Windows Media Player and the usual other DVD players.
But... when I went to burn it to disk following the recommended procedure I got the warning message about long rendering times, which suggests I did something wrong. I double checked the settings and they appear to be same between project and burn. The only thing I didn't do exactly per recommendations is at the capture stage I opted for 256 bit audio instead of 448, but I kept this consistent through all three stages. Any suggestions what I'm doing wrong. (By the way, there is not a "cancel" button on the dialog box that warns of the long rendering time.)
Any suggestions would be appreciated.
Questions regarding "recommended procedure"
jchunter
The warning about "converting videos and long rendering times" had to be tempered when Video Studio 10+ was released because enabling "Motion DVD Menus" triggers that same warning. I thought I had changed the wording but will double check.
Motion Menus does actually trigger a "convert videos" phase as it creates the menus from sections of your video, which can add 10 - 20 minutes to the burn phase.
If you want the fastest DVD burn phase, uncheck the Motion Menu option for every level of your DVD Menu.
I would ignore the message for now and go ahead with the burn. If you have problems report back.
Jeff
Dentler's Dog Training, LLC
brodwidr
- motherboard: Dell MoBo 0M3918
- processor: Intel Pentium 4 3.00 GHz
- ram: 1.5 GB
- Video Card: NVIDIA Quadro PCI-E Series
- sound_card: built-in
- Hard_Drive_Capacity: 75 GB
Thanks!
Thanks for the advice. I wasn't doing motion menus. I went ahead anyways and it worked! Terrific!
- David
- David
