VS9 Burn to DVD
paulwho
VS9 Burn to DVD
Post by paulwho »
Hi all > I need to burn some PAL TV programs onto DVD through UVS9 & to be viewed in Japan. Can anyone help me with the settings i would need to do this. Thanking you in advance.. Paul
Paul
Corel Video Studio Pro X2, Windows 7 64bit, Asus P5Q Motherboard, Asus Nvidia 1GB GeForce 9600GT, Intel CPU 775pin 9400, G.SKILL DDR2 1600 8GB 8500, 2 x SEAGATE SATA 3.5 HDD 500GB 16MB Cache
Japan of course uses the NTSC system, so you would need to convert your PAL video to NTSC -- not an easy task, and in any case, one which is unlikely to produce a smooth result. PAL speed is 25 frames per second, whereas NTSC is 29.97 frames per second. In other words, extra frames will have to be added to bring it up to the NTSC speed, and this means that some frames will be copied and repeated, making for a potentially strange effect. In addition, the frame size in PAL is 720 x 576, whereas for NTSC it is 720 x 480.
While it can be done, I am not sure the effort is worth it. Others might disagree (and probably will! :lol: )
Here is Australia, as you will know, most of our PAL DVD players will play NTSC DVDs with no trouble. The same is not necessarily true of NTSC players, apparently. But I would have thought that if anywhere in the world was going to have overcome any problems in this regard, it would be Japan.
So my own advice would be simply to prepare your DVD in PAL format and send that. And then hope that your recipient(s) will not have any difficulty in playing it.
paulwho
Post by paulwho »
Thank you Ken for your thoughts & I'll take your advice & go with the PAL DVD & see what happens. Regards Paul
Paul
