Editing problem
mikecampbell
Editing problem
How do I edit videos I took while not connected to the computer, how do I actually take the video on my tape and put it on the ulead videostudio 5.0 DV software? I have the ilink cable plugged in an everything but no manual and I'm very new at this, can someone please help? Thanks.
Max Sendit
re: how to edit with video studio
I've never worked with Video Studio 5 but I would assume it is somewhat similar to Video Studio 7. There are tutorials on the Ulead Website for Video Studio 7 which should be of help to you. Download the video tutorials for Video Studio 7. They are very informative. Good luck. You might want to consider an upgrade to Video Studio 8. It has some excellent features.
Download VS 5 Manual from:-
ftp://ftp.ulead.com/pub/Manual/VideoStudio5/
Think this is the English version?????????
VStudio5e.zip
VStudio5e.zip
mikecampbell
mikecampbell
rwindeyer
Welcome to video editingmikecampbell wrote:woah figured it out but about 5 minutes was an entire gig, any tips on lowering the file size without sacrificing too much quality
You do have another choice - if your computer has pretty impressive specs and can handle a high workload. You can save to mpeg format. This is the compressed format that gets loaded onto a DVD. Re-encoding video "on the fly" is pretty demanding, but mpeg video occupies much less space.
Be aware though that if you intend to do lots of editing in your project, mpeg video has potential drawbacks - DV is the preferred format.
Max Sendit
Mike, A suggestion for you.
Mike,
One suggestion I have for you for capturing in MPEG 2 format (files are considerably smaller than DV-AVI) is a product called Instant DVD 2.0 or Instant DVD+DV. This product has some of it's own resources and takes the strain off your CPU when capturing and converting to the MPEG format. This product will not capture in DV-AVI format. You can check this product out on the ADS website www.adstech.com. I own this product and use it for captures that don't have to be in the DV-AVI format such as those that do not require extensive editing. It is very easy to use and gives impressive results. If you shop on line, you should be able to find good deals on it as well. Good luck.
