Multi-tasking with Video Studio 10+ and Nero 6
kjfrey1701
Post by kjfrey1701 »
I want to multi-task as I'm working in Video Studio 10+
Tasks:
1. Adding video files to the timeline, creating chapters with chapter points in the Chapter Point Bar, performing Share > Create Video File.
2. Using Share > Create Disk to add video file above, create menus then create DVD folders.
3. Burning the DVD from the DVD folders (using Nero).
I know that these steps should be performed without doing anything else with your computer in order to make sure the DVD's don't have glitches.
Given my system, it seems that I should be able to do at least two of these at the same time. I wondering if this is possible either by just working on a VSP project and a Nero burning at the same time, or running one or the other in a Virtual PC on this machine.
My system:
Windows XP Professional Service Pack 2 (build 2600)
3.00 gigahertz Intel Pentium 4 (Multi-threading)
16 kilobyte primary memory cache
1024 kilobyte secondary memory cache
Board: Intel Corporation D915GAV AAC64134-402
Bus Clock: 200 megahertz
1536 Megabytes Installed Memory
Drives
LITE-ON DVD SOHD-16P9S [CD-ROM drive]
PIONEER DVD-RW DVR-111D [CD-ROM drive]
ST380817AS [Hard drive] (80.02 GB) -- drive 0
WDC WD2500YD-01NVB1 [Hard drive] (250.99 GB) -- drive 1
ST380021 A USB Device [Hard drive] (80.02 GB) -- drive 2
Post by Black Lab »
Why don't you try it and find out? Use an RW and you have nothing to lose.
kjfrey1701
Thanks Jeff. I'll give it a shot. I just didn't want to re-invent the wheel if one of the more experienced members had already worked this out.
Post by Black Lab »
Well, it's not usually recommended, if only to avoid problems. If it works for you, great.
heinz-oz
Post by heinz-oz »
Any of the more experienced members around here, as far as I can tell, advise against it :wink: Hence, there might not be any in depth experience to share with you.
By all means, give it a shot and let us know how you go. I would personally be very interested to find out how you go with burning out of Ulead VS when NERO InCD is installed.
