With great satisfaction I can say I got my VS10 to work on my PC!!
I have created videoediting profile as sugested by sjj1805.A lot of work but it should help much.Unfortunately after all that, as I opened VS10 under new profile there is no SOUND for any of the software that it should have it(WMPlayer,QuickPlayer or VS10).I must of disabled some service that holds control over this!!Does anybody have a sugestion???
Thanks much!!DadoB
Thank U vary much!I should of said already that I have looked into obvious solutions so: windows audio is OK.Also other thinks,like diferent transfer protocols.It did not make any diference .Any other sugestion??Thanks much for all input
check
Windows management instrumentation
Windows management instrumentation driver extensions.
Otherwise you might be looking in the wrong place.
Check the Device Manager settings to make sure you haven't disabled
something you shouldn't in the
Sound video and game controllers section.
Thank you for your sugestion.If there is a change in the Device Men.it should influence sound all over???My problem is only as I log on to the videoediting log in under separate profile. In the Normal log on all is well!! ???
Thank you again!There is no sighn of problem in the Device Men.Also my problem shows only in the VideoEditing log on.In the normal one there is no problem Do U mean to chek Dev.Men in the videoediting log on??I'll look into that too dadoB
