Hello, my english is primitive (I speak Spanish), I apologize about this, but I need to capture from mi analog camera NTSC from composite video to mi TV Tuner Kozumi with Conexant BT878 chip.
When I want to capture , the image is bad, but when I configure the properties and change mi Tv System from PAL to NTSC , the image is good, but when I push accept, the image returns to bad without accepting the change and it stands on PAL.
I have DVDMF 4 SE, that came with mi ASUS DVD Burner.
I can capture good from Honestech soft (It comes with the TV Tuner) but why can't I do the same with DVDMF if it recognizes the chip?
What can I do? .
Can you help me?
Thank you
HELP ABOUT ANALOG CAPTURING FROM CAMCORDER NTSC
I don't know why... Some capture-software and capture-hardware do not work well together.I can capture good from Honestech soft (It comes with the TV Tuner) but why can't I do the same with DVDMF if it recognizes the chip?
Or, maybe you are using different bitrate or resolution settings.
It's almost always best to use the software that came with your capture device. (Of course, you can experiment with different software.)
After you have a digital video file on your hard disk, you can use the software of your choice to edit the video and to author & burn the DVD.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
