Bojan1983 wrote:
How to make when I insert DVD into dvd player to see options "watch movie", "pick a scene", "look at photos"...
For every video file you place in the DVD Authoring module (Share|Create Disc), you get what's called a "hot spot", or a clickable link to some position in your movie. This is what I do to create the results you want: First I create a separate video file that is made up only of a 4 second black color clip and I place it first in the Authoring timeline. This will create a clickable "hot spot" in your main menu. I usually select a Text Menu for my main menu. Change the name of this hot spot to read "Play Movie", like a commercial DVD movie. When one clicks on this hot spot in your main menu, it will bypass your chapter sub-menu, and go directly to playing your main video file. The 2nd video file I place on the Authoring timeline is my main video file. This will create a 2nd hot spot on the main menu. I change its name to "Scene Selection". Back on the first page of the Authoring module, I click on the Add/Edit Chapters button and create my chapter points within this video file. This will also create a chapter sub-menu, with video thumbnails of your selected chapters. To get the "Look at Photos" selection, you will need to create a separate video file for your photos, and place it on the timeline as your 3rd video file. This again will create a 3rd hot spot on your main menu, where you can give it the name "Look at Photos".
"watch movie" should play whole movie, "pick a scene" should allow you to pick chapter, and "look at photos" should show photos (obviously )
The above suggestions will accomplish your aim.
what is the best way to add photos?
In your specific case, make a separate video file or slideshow with your photos. Create a video file from your slideshow. Create it using Frame based and a bit rate of 8000 kbps Constant. Add it as your 3rd video file in the Authoring timeline, as described above.
At the "menu" screen, on top I can choose "main menu", that is, I assume, menu which will appear when you insert dvd in dvd player... but what is "untitled"... which menu is that?
Not sure what you mean by "untitled"?
Also i want to know, at the final "burn disc" screen... which format should I use? DVD-Video or DVD+VR and what difference will be if I check those three boxes under ("create dvd folders", "create disc image file", "normalize audio"
You should typically select DVD-Video. I typically don't check those three boxes, but others that do could offer you some advice as to their advantages.
Good luck with your video.
