I gladly admit, that I learned a huge lot from this forums. Thanks to aaalllll the posters
As an enthusiastic motorcycle tourer, I am up to make a fun movie from my last trip. We used two camcorders and recorded 12-13 hours of video. Now I have to make a 60min movie out of this material
It turned out, that one of the camcorders is NTSC and the other one is PAL
The entire material is transfered to my computer already as DV files(yes, I have a remarkable HDD capacity - all details in my profile).
Is there any particular advise; before putting NTSC and PAL video clips together into the same project ?
I already done some tests and produced a test DVD. PAL clips are OK, as expected. The NTSC clips are somewhat disturbed, with several diagonal intersections throughout the entire screen (as if someone sliced the picture diagonally into several lines and tried to stick them together).
The overall quality, is still at the minimum expectable level for an amature, but I wonder if there is an other pre-treatment for the NTSC files to be converted with less damage ?
A second but less important question would be; that I have to re-capture some videos, as they don't play on WMP10. The first frame appears on the video screen of VMP10 but doesn't play, the video stays still as if PAUSE is engaged. I can move the progress indicator and get another still picture. If I re-capture the same video again, chances are high that this doesn't happen again. I can live with this but, if there is simple explanation...?
I am using VS9 (for now and considering to upgrade to VS10+)
I am using Sony TRV-110e.
Capturing via FireWire.
Thanks in advance, for all the support and advice.
Kind regards
Kaya - the XXL
