I have lifeview capture device with my tv plugged in via AV in.
When I activate ULEAD movieFactory 5 and start capture my only choice on the list is Analogue TV. The drop down menu does not show my lifeview device driver so I can't click on it. Basically the only choices it is giving me is direct cable attachment or direct attenae attachment but no av in or S cable in.
How do I change it so I can capture from my TV.
FYI ULEAD 4 captured just fine from my TV with this, lifeview device driver, and I don't recall me doing anything special other than hitting the drop down menu and selecting the lifeview device driver and I think channel 4 also to do it.
I don't see anywhere in preferences or anywhere else like an options to add my lifeview driver as a valid choice to the capture menu.
[edit, changed ULEAD 3 to ULEAD4 as the product I've used to capture using lifeview device driver before fin.]
[edit2 got it to work via advanced setup]
Capturing TV -- new problem, no sound.
slyhunter
slyhunter
While capturing the picture and sound plays fine over my computer. However, the resulting mpeg when played has no sound.
I muted each line individually and know for certain the tv sound is coming in on "line".
Again while on the capture screen the tv sound plays on my computer speaker fine. And while capturing the sound plays on my speakers fine. But when I play the resulting mpeg I get no sound whatsoever.
I did install all 3 patches for dmf5.
On side note the selection mono/stereo doesn't have a filled in dot. When I fill in dot and hit ok then reopen screen it unfills the dots again.
