As a new user of this forum I certainly checked if I could find something about my problem - I did, but I thought it might still make sense to describe the issue for other new users. And, probably someone has a short clear fix for me and others.
The issue: Since I switched from VS9 SE to VS10 pro the results of the DVDs I created are not smooth, which means that dependent on the scene the video plays choppy: fast scenes: more choppy, slow scenes: smooth. This never happened in VS9 SE. The basic video material I use are MPEG files generated by an ADS DVD Express DX2 box or by a Technisat SkyStar2 card.
I also noticed that under VS9 SE very often the original MPEG file was not rendered again if it was fine in length. Under VS10 pro it always does, and, yes, I checked the box that it should not render when the file fits.
I have tried to change the frame adjustments according to the original file , e.g. upper half, with no improvement. I may not use the right words here as I work with a German version of VS10 pro - but I hope you understand.
Yes, I worked with files that are ok and created excellent results under VS9 SE.
Thanks for your help
