Previewing Menu Templates
hador7
Post by hador7 »
Hi, I am using Version 10.
Is there a way to preview the DVD Menu Templates (including sound) on computer? I don't want to waste DVD-R's and time burning them.
OR Is there a way to burn several menus into one DVD so that I can see how each of the different menus look while wasting only 1 DVD-R.
And a 2nd smaller question, is there a way to reduce the opacity of a certain text in a Title Track? I want it to be semi-transparent so that some of the background Video Track shows through the text. Thanks!
Hador
Post by Trevor Andrew »
Hi Hador
In the burner module,
De-select Create to Disc
Select Create DVD folders
This option will create files, a TS- Folder containing all the dvd info, menu¡¦s and all.
I use Power DVD to play these files in my pc.
Otherwise use a DVD-RW disc.
Titles
There is a transparency option in the titles property panel Border/Shadow/Transparency
Setting the lower left box higher gives more transparency.
The box immediately above selects the border width.
Hope this Helps
Trevor
GeorgeW
Re: Previewing Menu Templates
Post by GeorgeW »
hador7 wrote:Is there a way to preview the DVD Menu Templates (including sound) on computer? I don't want to waste DVD-R's and time burning them.
Have you tried the little remote-control icon under the bottom right of the preview screen for the DVD Simulation?
George
