Symptoms: Crash occurs while burning to DVD folder, shortly after starting, while it is partway into "Converting title..." and "Converting video of the title...[001/001]". Null pointer error ("instruction at 0x07323ad0 referenced memory at 0x00000000").
Environment: Windows XP Pro, SP2. Tried on two different computers, and get crash at same step. MF5 Plus (TBYB) version 5.30.0107.0 according to 'About'. (Is there any way to check that from a file version? I tried MF5 5.0 TBYB before that -- not plus -- and maybe it didn't uninstall right??) Movie clip is about 1 hour or MPEG-2, UFF, 24 bits, 720x480, 4:3, 29.970 fps, 6500 kbps, with 384kbps MPEG stereo audio, which was captured via an Adaptec AVC-2010 PCI card, coming from an old analog Video8 tape (note: same crash whether I start with the MPEG captured with its original myDVD software at 6000 kbps, or with the new captures using MF5.0 or MF5.3 Plus).
What I've tried: I have already tried making sure the project's MPEG properties are the same as the clip properties. I have tried different menu types -- even text menus, different multi-trim edits (including just trim at start and end). Problem is consistent -- everything works nicely until I try to burn, and then it crashes. Argghhh! If I don't multi-trim at all (no scissors shown in the upper right corner of the clip image), then it burns to folder with no crash.
Please help. I am going out of my mind after having many other kinds of problems and crashes when trying myDVD 9 Studio Premier (got refund, thankfully). It's like none of the inexpensive DVD authoring software on the market is even usable, and I've wasted a couple weeks of my life trying! I use PhotoImpact, and hoped Ulead's MovieFactory would save me...and everything works great in MovieFactory 5 Plus (much better and stable than the current release of myDVD 9) -- UNTIL it crashes on the burn, which makes it useless.
Oh, and did I mention "Please help!"?
