Lost decoration files
hanskru
motherboard: Ultra Durable Gigabyte Technology
processor: Intel Core i5
ram: 4GB
Video Card: NVIDIA GeForce 8400 GS
sound_card: High Definition Audio
Hard_Drive_Capacity: 500Gb
Monitor/Display Make & Model: ASUS All i8n one
Corel programs: Ultimate 2020 upgrade
Post by hanskru »
Hi VS Friens,
Using VS10 since September,suddenly I cannot acces my decoration files.
I got the message: Unable to open file C:\Program Files\Ulead Systems\Ul...\MotionF01.swf, File Format Mismatch.
Any suggestions?
brgds Hans
Hans
VS 5.0,6.0,7.0,8.0,9.0,10,12, X3, X4, X5, X6 Ultimate,X7 Ultimat, X8 Ult, X8.5 Ultimate,VS1018Ultimate, VS2019Ultilate,VS2020Ultimate
JVC Everio GZ GX1BE
Post by Trevor Andrew »
Hi Hans
Are you still having these problems
In a recent post you lost the decorations and were able to recover using the info from this post.
http://phpbb.ulead.com.tw/EN/viewtopic. ... ht=filters
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=17854
From Terry If you close Video Studio and delete the uvs.ini file in Documents and Settings\username\applicatian data\ulead systems\10.0 and then re-open video studio, it should resolve your issue.
_________________
Terry
It is strange why it is occurring to some and not other users.
Please report the problem to Tech Support.
Hope this Helps
Regards
Trevor
hanskru
ram: 4GB
Lost flash animation
Post by hanskru »
Hi Trevor,
sorry I lost the Flash animation files (and not the decorations as reported) and by deleting the uvs.in file in documents and settings\username\application data\ulead systems\10.0 it did not solve this problem.
So any suggestions?
brgds Hans
Hans
JVC Everio GZ GX1BE
hanskru
ram: 4GB
Post by hanskru »
Hi VS Friends,
by some more checking it turns out that all Video samples in VS10.0 like flash animation, end visoe's ... cannot be shown, same error message as mentioned in my first report,
brgds Hans
Hans
JVC Everio GZ GX1BE
Hi Hans
It¡¦s a similar problem, and the fix is the same , I think, deleting the correct file will allow VS to reboot and replace the faulty file.
I do not know which file this is, but do a search on the forum.
As far as I know, deleting the files was a quick fix instead of doing a ¡¥repair¡¦ to Video Studio.
If you take this option (repair) you will also reset the library content to its default.
The problem is why is it happening to you????
Regards
Trevor
sunshinegirl690
Post by sunshinegirl690 »
I can't use my flash annimation either! The thumbnails show, but it is all black when you insert it to the timeline. When selecting properties, the message says the content of the file is unreadable! What's up with that? I did a repair which cleaned out the pictures decorations etc BUT did nothing to the flash annimation? Do I need to uninstall and reinstall?
