Please help me ! having probleme with 16/9 dvd autoring
hdvairwolf
Post by hdvairwolf »
:?: Hello, i realy need help and excuse for my bad english, i have encoding a video with Canopus Eldius 4 on 16/9 projet, on my eding sofware it work rely good in 16-9 and on it fille it write to. but on ulead when i made my dvd he detect that in are in 16-9 i choose the 16-9 box but when i burn it play in 4-3 mode
can you help me ^^^^??
many thanks mike
GeorgeW
Post by GeorgeW »
Which version of DVD WS are you using? 1.x, 2.x, Full, Express, SE, other :?:
DVD WS 2.x does not do 16:9 menus, so the menus will always be 4:3.
Do you mean that the VIDEO is 4:3?
Can you rt-click on your source video (on the timeline within DVD WS 2.x), and post the properties here?
George
hdvairwolf
thanks
Hello, i use the version 2.0 full and in mean i want my video only on 16X9 and i click on the icon i se the display option but i cant change the wide scren seting
many thanks
GeorgeW
Post by GeorgeW »
Do you mean that the VIDEO plays back on the burned dvd in 4:3 :?:
Can you rt-click on your source video (on the timeline within DVD WS 2.x), and post the properties here :?:
hdvairwolf
yes it playback on 43 and i have a 16X9 TV
Propretie
file format MPEG2
atribute 24 bit , 730x480, 16:9
frame rate: 29,970
data rate: 7000 kbps
hdvairwolf
ypou can see also a images snashot
http://www.productionsvideoms.com/mike.jpg
many thanks
GeorgeW
Post by GeorgeW »
hdvairwolf wrote:yes it playback on 43 and i have a 16X9 TV
Propretie
file format MPEG2
frame rate: 29,970
Do you mean 720x480 (instead of 730x480)?
Are you creating NTSC or PAL DVD?
That setting in the picture looks ok -- it should show as Letterbox on a standard TV, but should be widescreen on a widescreen TV.
Is the program re-converting your mpeg source? or is it using it "asis" (in the EDIT step, the box that says "Convert to disc Template" -- is it blank, or is it checked off or "ghosted") :?:
hdvairwolf
i using ntsc .
is not corect my 720x480 ?
GeorgeW
Post by GeorgeW »
For NTSC, 720x480 is good (you wrote 730x480 -- I just wanted to make sure you meant 720x480).
Do you have software DVD Player on your computer? If you use software on your computer (WinDVD or PowerDVD), does it play back in widescreen mode on your computer :?:
hdvairwolf
the convert disc template or not cliked, what is that ?
is it my trouble ?
hdvairwolf
i saw also when i burn to disc the disc template and i check te seting on that on propetries
dvd- ntsc , 4:3 !!!!
i cant change that
GeorgeW
Post by GeorgeW »
hdvairwolf
ok on my laptop when i take a 16x9 mode it play full ..... why on my tv dosent play full 16x9 because i know my seting are corect because when i use my editing suite it wor perfect
many many thanks for your good help, you helpo me and i apriciate
hdvairwolf
but can i have the way to put my video full 16x9 on my tv ? why it work corect on laptop and on my tv it dont work ?
GeorgeW
Post by GeorgeW »
hdvairwolf wrote:but can i have the way to put my video full 16x9 on my tv ? why it work corect on laptop and on my tv it dont work ?
Have you played a Retail Widescreen DVD in that DVD Player? Did a Retail / Hollywood Widescreen DVD Play as widescreen?
Maybe you have to go into the setup of the DVD Player, and setup the playback display mode?
