Comments ref User Recommended Workflow for VideoStudio
david reece
"Stickies" for ordinary users have not been implemented on this Ulead board either - although it is a readily available and very useful feature available on the phpBB - along with the facility to edit your own post.
The icon at the bottom of the page with "sticky" against it just shows what the 'flag' (on left hand edge of threads) would look loki if we had stickies.
jchunter_2
Stickies for New User Help
Three days ago I sent an email to the webmaster of this site with a request to make two stickies: The first would be the "NEW USERS PLEASE READ..." post and the second would be a copy of the Recommended Procedure.
I have not received a reply.
BTW, I also requested that users of this forum be allowed to edit or delete their own postings.
Perhaps we all should make the same request to the webmaster...
jchunter_2
jchunter_2
david reece
yes i have discovered an annoying thing in this forum. if you get to the bottom of the page and tab you lose everything you have typed.
As to July being the last cut off date so far. are you sure! or have you not marked read in a long time?
There was some good stuff in there.
My opininon and i am sticking to it with or without a Sticky (lol)!
david reece wrote:As to July being the last cut off date so far. are you sure! or have you not marked read in a long time?
Ok I've found some in there for June but it's easy to check David just go back to the old forum make sure you have 'all messages' selected and then go to the "bottom" or end and you'll see for yourself.
IronMike778
When I follow the "Create Video File" instructions that you've laid out I get terrible results. The video breaks up in several spots. However, if I just save it as an mpeg2 (rather than 'same as project settings' or 'customize') it save real nice.....no flickering screens or break ups. Any idea as to why? I just wonder if I'm selling myself short of having even a better quality production.
jchunter_2
IronMike,
The Recommended Procedure is to make a video file from your project and select "Same as Project Settings" only if you have captured to Mpeg and have previously set up your project properties to match your captured video properties.
Please post your captured video properties and your project properties and we can try to see what happened.
