Render vs. Play
sgraham
Render vs. Play
Post by sgraham »
I am a longtime version 8 user. I make a lot of short promo clips. Typically I would go in to Share and set the Mark In and Mark Out and play the clip before rendering. Although baloon help says 'Play Trimmed Clip', when I hit play the program tries to render the clip/project. Going to Clip Mode throws me back to edit and the Mark in/out is not the same. I have not been able to figure this out, help appreciated. - Steve
Post by Trevor Andrew »
Hi Steve
Have just tried VS 8 with no problems, not that I normally use the Mark in / out function,
Have you selected High Quality Playback in File Preferences¡XPlayback Method. This would force a render prior to playback in project mode
Regards
Trevor
sgraham
Sorry I should have been more specific
Post by sgraham »
In version 10 that I upgraded to, you set mark in and out and it says play but hitting the play button it starts to render. very frustrating. Not same behavior in 8 but am now on 10 and still need help. The 'new' clip view, project view is no help at all, very confusing...and this from a long time user. I have made over 150 movies with 8 and still having problems with this simple task. other modifications/feature adds are great.
Post by Black Lab »
You didn't answer Trevor's question. Go to File>Preferences>General Tab. About halfway down you will see Playback Method. Choosing High Quality will render the file before playback. Instant Playback will playback, um, instantly.
sgraham
Thanks!!!!!
Post by sgraham »
sorry, tired here this morning. that fixed it. much appreciate. very disingenious of Ulead
Sorry to rain on your parade, especially when you are tired! :lol: But I am afraid that that particular Preference was identical in VS8 as well. I just checked my own installation of VS8 to see that was the case. Unfortunately, I no longer have VS7 installed, but I distinctly recall it being in that too, as it is in VS9 and now 10... So you must have looked at it at some stage... :roll: :wink:
I agree with you Ken, the default setting is Instant Playback.
If High Quality Playback was selected then this has been done manually by the user.
Unless there is a fault with installation. :?:
Trevor
