Videostudio 10 encode better in batch mode, why?
saroga
Post by saroga »
I have captured analog vhs avi (Huffyuv v2.1.1 codec) with videostudio 10, when encode 1 min. video to mpeg with this settings, in batch and normal mode, I get better results in batch mode, why is this?
Encoded to this settings:
MPEG files
24 bits, 720 x 576, 25 fps
Upper Field First
(DVD-PAL), 4:3
Video data rate: 8000 kbps
LPCM Audio, 48000 Hz, Stereo
This are the results in bitrate viewer:
Batch encode videostudio 10:
Bitrate: 6386
Q.level: 1.85
normal encode videostudio 10 (share\create video file):
Bitrate: 6363
Q.level: 3.69
U can see, that the Q.level is higer in the normal mode, why is this?
and this is the complete information from the bitrate viewer:
Num. of picture read: 1277
Stream type: MPEG-2 MP@ML CBR
Resolution: 720*576
Aspect ratio: 4:3 Generic
Framerate: 25.00
Nom. bitrate: 8000000 Bit/Sec
VBV buffer size: 112
Constrained param. flag: No
Chroma format: 4:2:0
DCT precision: 9
Pic. structure: Frame
Field topfirst: Yes
DCT type: Field
Quantscale: Nonlinear
Scan type: Alternate
Frame type: Interlaced
Scene change detection: NOT FOUND
Variable GOP pattern: NOT FOUND
Notes:
