LFF, UFF or Frame Based
Post by Trevor Andrew »
Hi Jeff
Not very interesting results really.
What I have is 12 Dv-Avi files 55 minutes in total.
I need to convert to 12 mpeg at 4000.
Never considered batch convert and always used the timeline. Inserting each clip in turn to Share Create Video File.
So when I did use batch convert the process was much quicker, or so I thought.
The actual rendering was the same for each method, but what I did save was the time it took to reload a new Avi to the timeline. I know its just a matter of replacing the file, drag and drop from the library.
Unless I am glued to the pc watching the progress bar then I loose further time not knowing the process has finished.
I don¡¦t suppose many users make 12---- 5 minute videos.
If you have a lot to do then that¡¦s what Batch Convert is for. The name does give it away though.
I would have liked to have the option to choose a template rather than inputting the properties by hand. By using a template means I always use the same settings and not rely on me to remember them.
I will use it again
Regards
Trevor
Ps render was in real time.
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 11:19 pm, edited 1 time in total.
jchunter
Post by jchunter »
trevor andrew wrote:I insert the mpeg2 file , allowing VS to change the project properties to match the video properties. I do not have to enter any properties VS does that for me.
I have, all too often, seen incorrect property defaults in Video Studio. I have no idea where these wacko property values come from. :shock: - possibly because I work with a lot of different video file formats. I don't have the time or interest to debug the "system" of defaults but my workaround is to never trust VS default values - instead, I set every property manually, every time, in every stage of the editing workflow. This works every time.
I work with projects along side my step-daughter, in the early days she did not comprehend the properties of a video file. ( in fact neither did I, its one of the hardest things to learn ) I think she may have grasped the concept by now, hope she isn¡¦t reading this.
Any how by creating a template using movie manager we couldn¡¦t go wrong.
I just told her to go Share Create Video File-My Template.
It would be nice if Batch Convert had that option.
I haven¡¦t had a problem with VS displaying or using the wrong template.
Trevor
