Hi.
When trying to burn a video dvd MovieFactory stops and reports "Failed to create vob folder"
I can create a slide show on dvd ok
Can anyone tell me what I am doing wrong.
davecol
Hello again
I should also point out that I have this problem with both Moviefactory 4 and moviefactory 5 plus
davecol
Hi George. This is the properties of one of the files. Does this help?
MPEG files
24 bits, 720 x 576, 25 fps
(DVD-PAL), 16:9
Video data rate: Variable (Max. 7000 kbps)
Audio data rate: 256 kbps
Thank you
MPEG files
(DVD-PAL), 16:9
Thank you
That helps -- can you create a small test project using just that single file you listed (make sure "do not convert compliant mpeg files" is selected, and output to dvd folders on your hard drive)
What are your project properties
Also, are you using TRIAL versions, or "lite" or "SE" versions of the software
George
George
davecol
Hello George.
It worked ok using the single clip. I am using version 5.30.0107.0 of Moviefactory 5 plus which I bought and downloaded from ulead, but I have had the same problem with Moviefactory 4.
Thanks for the help. I'll try more clips and see if it fails.
Dave
Dave
davecol
