Creating Place Holders
MaryLouW
Post by MaryLouW »
I would like to create my own backgrounds for the Photo Projects in PI12. When I attempt to save the screen I created with a .upf extender (that's the format for project files) I get a message saying that I need a place holder. The place holder is the area where the images appear when you create a photo project.
I have checked the help files and cannot find any information on this. The same applies when making DVD/CD labels and packaging. I need to create place holders if I want to make my own templates.
The place holder appears to be an "empty" box with selection lines and when you insert your own image, it seems to go down a layer because you can drag it all around the empty box until it's right where you want it.
Any suggestions??
[url=http://pircnet.com/]PhotoImpact Resource Center[/url]
[url=http://wwell.net/]Wishing Well Tutorials[/url]
[url=http://pircnet.com/forum]PIRC Forum[/url]
njdowding
Post by njdowding »
MaryLou
To create a place holder is quite easy
Make an object of what you want as a place holder
Make a layer mask of the object (you need to change from a path to an image before you do that.
Right-click the object and then select Properties and in the general area you will find a tick box for place holder. Tick it and its done!
Nick
MaryLouW
Post by MaryLouW »
Nick, I'm not sure what you mean by "make a layer mask". Can you expand a little on t hat?
njdowding
Post by njdowding »
MaryLou
Maybe my terminology is not quite right but to do it you would either select the object that you want to add a mask on or select it in the layer manager (in this case it would be the thing you want as your place holder). Use the selection tools to make a selection on a part of the object that will show the grapic in the place holder (in most cases this will be the whole object)
Click Create a new layer mask (in layer manager) to change your selection into a layer mask. You can go into mask mode as normal and adjust it as you like
Thats it you have created a mask or as PI call it a layer mask
Nick
MaryLouW
Post by MaryLouW »
Thanks, Nick! I found something in the Help files - finally. I was looking for the wrong thing. Going to give it a try. Sure glad you're there to help when needed. Something you said in prior message pointed me in t he right direction. Will let you know the results.
MaryLouW
Post by MaryLouW »
Well, I did it! I managed to create a new template with a placeholder and it worked just fine!! It took me a while and I'm not positive I understand what I did but I'll do it a few more times and it will become clear. Thanks for putting me in t he right direction! Now I have a new toy to play with. :D
njdowding
Post by njdowding »
Glad it worked. Its one of those things that I know how to do but is quite hard to explain to someone else lol.
Nick
MaryLouW
Post by MaryLouW »
Nick, even Ulead's help file is hard to follow! They write things on a non-beginner level, just assuming you know what all the other tools are and where to find them. That's what makes it difficult.
The reason I want to understand this is, I want to do a few tutorials at a beginner level in that area. A bit more practice on my part so I have a good understanding is in order. Thanks again.
Tell me though... could I use this same method to create my own menu's for PictureShow 4?
njdowding
Post by njdowding »
MaryLou in theory not I think. But maybe it is possible. I will have a play and let you know.
Nick
MaryLouW wrote:Nick, even Ulead's help file is hard to follow! They write things on a non-beginner level, just assuming you know what all the other tools are and where to find them. That's what makes it difficult.
We look forward to reading them.
Thank you.
