BD-R/RE disk on a PS3
plee
Post by plee »
Has anybody created a BD-R/RE disk using Moviefactory and played it on the PS3? Also, are the chapter stops working? Thanks.
htchien
operating_system: Mac
Post by htchien »
I was been told yes it will work if you use DVD MovieFactory 5 Plus. However I can not verify it because I do not own both of them (BD/RE and PS3) and will never buy them.
H.T.
Ted (H.T.)
dscott
Post by dscott »
I have actually got it to work with the 'plus' version of the software. The disc played on a PS3 running the 1.06 firmware.
My question is, does anyone know how to prevent the app from re-encoding the clip that I import? In the settings there's a check box that says something like 'Don't re-encode compliant streams', but it does not seem to work.
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 9:05 pm, edited 1 time in total.
There is no BEST. It's what works BEST for you.
Hutflesz
Imported File Properties
Post by Hutflesz »
The Properties of the imported HD file are listed below:
FILE
File format: MPEG-2
File size: 95,420
Duration: 30.030 seconds
VIDEO
Video type: MPEG-2 Video, Upper Field First
Total frames: 900 frame(s)
Attributes: 24bits, 1920x1080, 16x9
Frame rate: 29.970 frames/sec
Data rate: 25000kbps
AUDIO
Audio type: MPEG Audio Layer 2 Files
Total samples: 1,441,441 Samples
Attributes: 48000 Hz, 16Bit, Stereo
Layer: 2
Bit rate: 384 kbps
[/b]
