Creating a burn DVD with multiple slideshows
Daniel M
Post by Daniel M »
Sorry, looking for help...
How do you add other slideshows to one DVD project?
michaeltee
motherboard: HP 82F1
processor: Intel Core I5 7400 3 GHz
ram: 16 GB DC
Video Card: Intel HD Graphics 630
Hard_Drive_Capacity: 2TB Hybrid
Monitor/Display Make & Model: Samsung S24D300
Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Re: Creating a burn DVD with multiple slideshows
Post by michaeltee »
Daniel M wrote:Sorry, looking for help...
No problem Daniel. After you've created your first slideshow, click the green "+" button next to the sunflower icon on the upper left of the "1 Organize" tab. From the menu that appears, select "New Photo Slideshow" and create your next show. Simply repeat this process until you've created all of your shows. From there, proceed through the standard additional steps to customize your menu, edit music, etc., (if desired) or just go straight to the "3 Burn" tab and burn a DVD.
Just FYI, each slideshow is represented by a thumbnail image on the left side of the UI of the "1 Organize" tab. You can drag & drop them to change the play position/sequence of your shows if desired. If you want to add additional shows at a later time, go to the file menu and save your project as a DPS file. When you reopen the DPS file, all of your shows from the saved session will appear exactly as you left them. You can then add or remove shows and/or re-edit your shows before burning a DVD.
-Mike
Daniel M
Post by Daniel M »
Thanks Muchly! This is the information I needed but couldn't find.
