Lose the DVD Folders option in Share > Create a Disk
kjfrey1701
Post by kjfrey1701 »
I'm using VS10+ and am having a problem after choosing to burn DVD Folders. I'm following the reco procedure to 1) make my storyboard, 2) Create Video File 3) open new project and choose Create a Disk 4) Open the video file and set up chapters and menu, then 5) burn either a disk or DVD folders. After doing this once or twice and starting on my next DVD, following the same steps as above, the only option I have at step 5 is to Create a Disk. I don't have the option to create the DVD folders until I shut everything down and reboot. Just closing and reopening the program doesn't help. I've also tried to reload the program to no avail. Suggestions?
System:
Windows XP Professional Service Pack 2 (build 2600)
3.00 gigahertz Intel Pentium 4
16 kilobyte primary memory cache
1024 kilobyte secondary memory cache
Board: Intel Corporation D915GAV AAC64134-402
Bus Clock: 200 megahertz
1536 Megabytes Installed Memory
Drives
LITE-ON DVD SOHD-16P9S [CD-ROM drive]
PIONEER DVD-RW DVR-111D [CD-ROM drive]
ST380021 A USB Device [Hard drive] (80.02 GB) -- drive 2
ST380817AS [Hard drive] (80.02 GB) -- drive 0
WDC WD2500YD-01NVB1 [Hard drive] (250.99 GB) -- drive 1
GeorgeW
Post by GeorgeW »
Is the option showing, or not showing :?:
If it is not showing, then try hitting the double-arrow to the right of the screen on the same line as the "Create Disc" line (this will expand to show more options).
George
kjfrey1701
It is not showing at all. I will check that as soon as I get home today. Thanks.
I vaguely remember seeing that once and then promptly forgot all about it. I'll bet that's it.
kjfrey1701
Bingo. Wow I wasted a lot of time for something so simple. Thanks.
