How do I find the transparent setting as described in the Help file.
5. Click Transparency. Select Transparency then set it to at least 75% to mimic the appearance of glass. Set the minimum transparency to 35% for the object's edges.
6. Click Shadow and select the Render backface option.
7. Click OK.
I can not find it? anyone know where it is?
Using PI 12
Transparent 75%
Not sure what page you are referring to, but there are at least 2 places to adjust the transparency.
1. In the Tools Settings-Path, if you have a 3D object, click on the More button. In the Material dialogue window, you should see in the left side Transparency. Select it.
2. In the Layer Manager, at the top of the Layers Tab, to the Right of the Merge Mode pull-down menu is where you can adjust the transparency.
Videocreator
heinz-oz
