MF4-- "Convert step got some problems! (4102)"
soonerjw
Post by soonerjw »
Okay, I've come to this forum because I don't know where else to go. I will do my best to explain my problem, but I will admit that I don't know enough to get into some of the nitty-gritty (If I did know that much then I might hnave been able to solve the problem on my own! :P )
I recently copied a video tape onto a DVD through my VCR/DVD combo player. Then, through DVD Movie Factory 4, I imported the 3 videos from the original DVD into a project file. I split those three video files into 13 different chapters within the DVD MF4 movie project.
Now, as I have finished creating the DVD-Video project, I am attempting to burn and after it warns me that "This step may take a while", I am then given a warning "Convert step got some problems! (4102)".
I have Googled and searched in this forum for some information on Warning #4102, but I can not find where anywhere has ever mentioned this problem.
I will include my system information if needed, but this warning made it seem more like a programming issue, so I have not included that information yet. I will say that I have tried to install the latest two updates (Aug. 2006 and Nov. 2006) from the website, but when I try to install it says that it can not find Movie Factory 4.0.
Thank you for any help or information (or simple guidance) anyone can give!!
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 9:21 pm, edited 2 times in total.
soonerjw
Post by soonerjw »
Sorry that its taken so long to reply with this information. I have been away from the desktop computer with the program for the past week.
Since you mentioned the possibility of the Dolby Digital Audio not being supported by the software, I will add that have never been able to have audio play while watching a DVD or a movie file through the ULead software. The project that I am trying to create/burn is made from a VHS tape being dubbed to a DVD, then copying that DVD onto my computer and editting the file through MovieFactory as a new project. Yet, I have burned one other project before using movie files that I downloaded from online sources, and that DVD has worked/played fine.
Here is the information from the Media Properties that you mentioned:
File
File name: _________
File format: NTSC DVD
File size: 300,780 KB
Duration: 485.419 Seconds
Video
Video type: MPEG-2 Video, Upper Field First
Total frames: 14,548 Frame(s)
Attributes: 24 Bits, 720 x 480, 4:3
Frame rate: 29.970 Frames/Sec
Data rate: Variable bit rate (Max. 4300 kbps)
Audio
Audio type: Dolby Digital Audio
Total samples: 23,300,100 Samples
Attributes: 48000 Hz
Layer: None
Bit rate: 256 kbps
Just for extra information, I'm using the MovieFactory 4.0 Suite Deluxe software that came bundled with my internal Pioneer DVD-RW drive. Not sure if that means its the Special Edition or not...
Thank you so much for all your expertise and help!!
maddrummer3301
