I installed PHotoImpact 11 under Microsoft Vista, which I have installed from my F: drive -
(I did this because Windows XP on C: - and I wanted to migrate a step at a time)
and like others (I learned from this forum) -
I found PhotoImpact would not finish initializing.
According the screen - it stopped while loading u32Ico.fio...
The solution (other than redoing the system to have a C: drive operating system) - is as follows:
MOVE
f:\Program Files\Ulead Systems\Ulead PhotoImpact11\Fio\FIORC.dll
to
f:\Windows\System32\FIORC.dll
You *must* delete the file from the Fio directory - if you leave a copy there - it still finds it in the Fio directory it fails to loads.
If you do not put a copy in the system32 directory - you'll find PhotoImpact loads but will not open photos any more.
I hope ULead will consider fixing whatever error is in there code - this has been mentioned on this forum for past versions.
A great piece of software - a minor bug once you know how to work around it -
I hope this helps others.
PhotoImpact 11 fails to load under Vista when not C:
reinders
Raptor8
Works for XP as well
Thanks, that was an easy and great fix. When I replaced my C: drive due to failure and reloaded XP it assigned it F:, seems pretty lame but once it does that it can't be changed. My P11 also wouldn't boot until I moved the FIOC.DLL file after which it worked fine.
Thanks!
Thanks!
staycool
heinz-oz
- ram: 2 GB
- sound_card: Intel GMA 950
The problem here is that Windows did not update the PATH statement to include the current location of FIOC.DLL.
There could be a dozen reasons why the PATH statement was not updated and could vary from one users machine to another.
Useful link:
How to set the path in Windows 2000 / Windows XP.
Useful link:
