Still Image capture from still image!
richiejazz
Post by richiejazz »
I use the make into single still image (snapshot) feature a lot from movie files, but can you do the same with existing still images?? The option to do so is always blanked out when I select one. For example, I have a photo with the pan effect on - so over about 30 seconds we are zooming in the the picture, but I then want to freeze frame that picture at a certain moment and fade out, not simply fade out before the zoom is complete etc
Any ideas??
Post by Trevor Andrew »
Select the frame to be saved as image
Use scissors to cut clip.
Switch to ¡¥project¡¦ playback mode
Use Tools-Save Current Frame as Image
This will take a snap-shot of the frame.
Insert still image at cut point.
Interesting effect.
Trevor
