Hi, I'm using MSP 7, I like to save image to image file (from the source window) the last frame of a clip, then put the saved image (saved as JPEG file interchange format) to the end of the clip on the timeline and extend it as long as I need to create a freeze frame. I find the freeze frame function a bit to hit and miss in regards to a shaky image when clip is played on a TV. The saved image is the same width and height in pixels as the video clip, but the saved image is always elongated-squashed together at the sides and this only shows up after I've created a video file,
my project settings are- Avi files,pal, 24 bits 720 *576 4:3 25 fps
field order A
anbody got any advice on this
Banton
still frame is a different size
I kind of bumped heads with this one as well, but, found, if you send the images to the storyboard first, then send them to the timeline from there, the aspect ratio is fine. You may have to edit the path, though, if it is not to your liking.
I was using VS10 to do my stills, but, actually LIKE the way MSP 8 handles it, as you have a LOT more control, espeacialy if you use cues. Syncing to music was never more fun..
