It just goes to show again that the obvious culprit is not always guilty.
I have always taken your approach also. If something doesn't work on my machine but works on others, my download is not corrupted, I followed proven procedure to install the program, there must be some issue on my machine.
I have had many problems over the years. Some were fixed by changing hardware, some by eliminating software incompatibility by choosing which programs/codec's to install/remove. On the odd occasion I resorted to a clean install of WINDOWS on a freshly bought or reformatted drive and invariably, my troublesome program would work.
PI 11 was the best example for this. I was using PI 10 and did the Beginners Workshop with it. I did a lot of projects with it, for the BW but also for myself. When I installed PI 11, immediately I had problems with PI 10 (with the mask tool which I had used extensively with no problems prior). I had the same problem in PI 11 also. Uninstalling PI 11 did not fix it. Reinstalling PI 10 did not fix it either. To cut a long story short, when I reformatted my drive and installed one program after the other, trying each one in between, I got PI 10 and 11 as well as MSP 7.3, Cool3D and others to work just fine side by side. I thought I had found the reason for my problems, WINDOWS XP.
Then, a few weeks later, I wanted to burn a project to DVD and realised that I forgot to install DVD MF 3 Disk Creator. So I installed it, burned my disk and was happy, until I wanted to do another project in PI 10, using the mask tool. The same problem again as before
I updated to DVD MF 4 Disk Creator and had no more hassles.
Good on you to work this out. Enjoy your program.
