Hi Everyone,
I've recently downloaded Ulead's free particle plugin, which I find really useful. I'm unable to save presets though. Whenever I click the "Add" button, I'm presented with a message box which says "Preset folder doesn't exist."
I'm not using PhotoShop. Instead I have tried it with Serif PhotoPlus and IrfanView, plus some other "compatible" programs. All give the same error.
I have tried installing to different folders, directory paths with simpler names (eg. no spaces) and creating dummy folders in ways which seemed logical to me (eg Adobe\Photoshop\Presets.) Nothing has worked.
Finally, I saw a review for PhotoImpact 8 which seems to incorporate the particle plugin's functionality. Is this still a part of the current version? Does it have a larger preview window than the plugin? Does it produce an effect with better resolution (ie. a bit less pixelated looking?) These two items (plus the presets problem) are the only faults I can find with this excellent freebie.
Many thanks for any help.
Mark Brown
Unable to save presets in free particle plugin
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
mabrown
Thanks for your reply Robert.
Unfortunately, I have exactly that path to the particle plugin. I also figured that "data" was the presets folder. I can actually load the standard presets, no problem. I just can't save any of my own
To see if this problem happens with the other plugin freebies, I installed the warp and art texture plugins. They work perfectly despite having exactly the same type of directory structure.
This is really weird. I'll try installing on another machine and see what happens.
Thanks for your help.
Mark
Mark
- VikingAnimations
- ram: 4 GB
mabrown
Hi again...
Well, this is the strangest computer problem I've had in quite some time.
I tried switching off read-only for the folder attributes but this didn't help. Tried to save another sort of file to the directory... no problem. Loaded the preset file in a text editor, modified it and saved it back to itself without problem. Tried to load the presets with the plugin using the modified file and as expected no presets would load (no error message though.) Restored the file, presets load but will not save, giving the same error message. Tried installing to the root of C. Doesn't help.
Installed the plugin on another machine and it works perfectly....
Mark
Mark
mabrown
I just fixed it!
The files and folders on this machine are compressed using the regular win xp compression. I switched off file compression for the plugin folder only and all of a sudden it works
What i don't get is that it didn't matter for the other two plugins. The other machine on which it worked first go also has file compression.
Very strange but I'm happy it works now
Mark
Mark
- VikingAnimations
- ram: 4 GB
