Saving used video clips
givensk
I want to start a new project but the program continues to displayed video clips from previous projects. I wanted to know if it was possible to start a new projects without the previous clips showing?
The clips are in the timeline, or the library? Clips in the library are normal, until you delete them. Right click on one and choose delete to delete the thumbnail. Right click on one, hold the Shift key and choose delete to delete the file from your computer. To delete several at once use typical Windows key combinations (Shift+click to select a sequence of clips, Ctrl+click to select random clips).
You may want to look into using the Library Manager to manage your clips. Put all you clips for a project in one library. When you are done just delete the library.
Jeff
Dentler's Dog Training, LLC
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Loibrary Manager
It makes things a lot easier if your clips ,files and projects are stored in the Library Manager then they can be deleted in one swoop.To access the L.M either Go Tools –Lib Man or select it from the list via the drop down arrow next to where you change the library type.Choose the media type then new-name it,select edit to amend name/description if required.You can then delete the named folders and their contents in one go when you want to.
regards Ken
regards Ken
