Why are my inserted images not filling the screen ???
weddingsbywayne
Post by weddingsbywayne »
Why does ulead 9 pop my images into the frame at the correct ratio and when i use ulead10 it gives me all black borders?
I did manage to get them fitting nicely then added some video and they all fell back to black borders again.
Very frustrating.
regards
wayne
heinz-oz
Post by heinz-oz »
It's even more frustrating trying to help with nothing to go by :roll: Did you check the settings in VS10 or are you one of the believers that software companies intuitively need to know what exactly it is that you want to do and provide you with the correct default settings straight out of the box?
I never used VS9 but just jesterday I finished a video in VS10+ which also includes a lot of still images, none of which displays a box around them, can you explain to me why?
WestbrookNH
motherboard: Hewlett-Packard 1631 KBC Version 01.33
processor: 2.30 gigahertz Intel Core i7-2820QM quad w HT
ram: 8 GB
Video Card: NVIDIA Quadro 2000M
sound_card: NVIDIA High Definition Audio 4x
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Generic PnP Monitor (15.7"vis)
Post by WestbrookNH »
Check the project settings.
If you are set for MPEG NTSC with a bit rate higher than 9800, you will get a 16:9 aspect ratio, not 4:3, and if you have "Keep Aspect Ratio" checked for your images, you will not be able to avoid the black borders.
Try using a bit rate of 9800 or lower for NTSC, 8200 or lower for PAL to render MPEG in 4:3 aspect ratio.
Unless you want to render a HD file ...
Post by Black Lab »
Also check File>Preferences>Edit Tab>Image Resampling Option. You can choose Fit To Project Size or Keep Aspect Ratio.
weddingsbywayne
Teachers and students
Thannk heinz-oz for the sarcasm but the reason i posted a question was to find out which settings i need to change........
Only a moron would expect a program to be rfu out of the box it came :o in.....
Anyway i'll battle on with adobe products that don't seem to jam the system either.
Happy new year :shock:
njdowding
Post by njdowding »
Wayne
In File/preferences/edit VS9 was probably set to fit to project size and VS10 as standard is set to keep aspect ratio. Just change this.
WestbrookeNH I am not sure how setting different bit rates will affect aspect ratio. The project can be set to 4:3 or 16:9 in the project settings.
Nick
heinz-oz
Re: Teachers and students
Post by heinz-oz »
weddingsbywayne wrote:Thannk heinz-oz for the sarcasm but the reason i posted a question was to find out which settings i need to change........
If you had bothered to put some detail with your question, I'm sure, the reply wouldn't have been the same. What sort of advice do you expect if you don't say what you did?
I wish you luck with Adobe.
