How to adjust time for frame overlay?
Matt G
Post by Matt G »
Nature of the problem:
My project involves inserting a frame overlay over a video clip. The only way I have found to adjust the length of the overlay is to "grab" the edge of it in the timeline view and stretch it to the desired length. I am hoping that there is somewhere to manually enter a length for the frame, so I can just type in the desired minute/second/frame length that I want it to be. Is there a way to do this, and if so, how can I access it?
Properties of your source files (format, file size, where did you get it?)
What devices are involved and their mode of connection?
None
Project Settings
(copied from "Project Properties" under the File menu)
Microsoft AVI files
24 bits, 720 x 480, 4:3, 29.97 fps
Lower Field First
DV Video Encoder -- type 1
DV Audio -- NTSC, 48.000 kHz, 16 Bit, Stereo
Output format (file, DVD, VCD, SVCD)
PAL or NTSC
N/A
Error Codes (if any)
N/A
Please let me know if I need to clarify anything.
Thanks.
Hi Matt,
Yes there is a way to do this. When you insert your image to the timeline, either overlay or main, then you should see a couple of tabs Edit and Attributes. On the Edit Tab, the first box which is numerical and has a clock to it's left, is where you set the duration for the image. You can press the up/down arrows, or just type in the numerical duration. The format is, HH:MM:SS:FF, (Hours:Minutes:Seconds:Frames). So if the video clip is 2 min, 20 secs, 10 Frames (0:02:20:10), then type that into the spin box for the image, and viola, the image will be the exact duration as the video clip..
heinz-oz
Post by heinz-oz »
I find it easier to just drag the edge to where I want the overlay to finish.
Matt G
Post by Matt G »
Thanks for the reply - that was exactly what I needed to know. I had missed seeing the additional tab.
