Have downloaded fron Canon camera. Have burnt DVD which plays on Computer, but when inserted in Toshiba integrated TV/DVD comes up 'incorrect disc'. On Liteon DVD player the message is 'put in a disc' .
Any help appreciated. Thanks
DVD Playback on TV
Right....
If you simply burned a video file onto the disc, it won't work. The video "data" on the disc needs to be formatted properly. This should happen automatically if you choose Create DVD. (Ummmm... I don't remember if Create DVD is exactly the correct terminology and I don't have Video Studio on this PC.
If you created menus and these menus appear when you play the DVD on your computer, then the format is probably OK.
Right-click on the DVD and choose Explore. You should find a VIDEO_TS folder and an AUDIO_TS folder. The VIDEO_TS folder should contain several files, including a few ~1GB .VOB files which hold the actual video (and audio). The AUDIO_TS folder will be empty. (You can compare the files on your DVD to any commercial DVD to see it it looks correct.)
Also, you should be aware that some stand-alone players can't play "burned" DVDs at all. And, some can play DVD-R, but not DVD+R, or vice-versa. some players have trouble with R/W (erasable) discs.
It's actually a good idea to use a DVD-R/W when you are first learning the software. Even after you're comfortable with the software, it can be helpful when you're making a complicated menu structure, or if you want to make sure the colors look right on a TV. (Assuming your player can play R/Ws.)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
You might have a compatibility issue between your DVD player and the type of media your using. You can check for compatibility issues here :
http://www.videohelp.com/dvdplayers
Sometimes burning a disc too fast can cause problems with playback on various DVD players. What speed did you burn the disc? It is recommended to burn no faster then 4x.
richardam
Non playingDVD
Thanks gentlemen. Will ponder your ideas and experiment. Expect some more pleas for help idc!
Richardam
Richardam
