Problems with photo slideshows
SergeyK
Post by SergeyK »
I use DVD MovieFactory 4.
I have tried to create photo slideshow with about 80 photos. I added all of them to slideshow and try to set a picture on slideshow menu. DVD MovieFactory alow me to select any picture from slideshow for menu. But, when I try to select a photo, I disclose that NOT ALL photos in the slideshow which I added. I can select picture for menu from about first 60 photos. I've returned to slideshow and I've seen all 80 pictures. Then I decided to select first photo for menu and create DVD. When I created the DVD I found that slideshow contains only 60 photos!!!
I've found one more thing. If I create new project (without closing a program) and add 80 photos and create DVD. Everything fine. But if I close the program, then I loose my 20 photos from the slideshow.
I tryed to remove slideshow from the project and create new one. It doesn't help.
Please give me workaround!!!
heinz-oz
Post by heinz-oz »
The work around would be what you suggested yourself.
Apart from that, I'm not quite sure what you are talking about.
SergeyK
Post by SergeyK »
That is not good workaround. Because you should create new project and doing everything one more time. I can't create slideshow with 80 photos.
I think that the problem is in wrong project file. Because I have reinstalled DVD MovieFactory but bug still exist.
I haven't found any info about such case.
