I am interested in the mask frames that can be applied to images in the overlay track. I can only find 14 masks to choose from in VS10+ (and most are not that useful to me).
Could someone explain in detail how to create my own masks using Paint Shop Pro X? Also, where do I place them so they can be used?
I have searched this board and read the manual but I cannot find any instructions for creating my own masks.
Thanks for any suggestions.
Woodchuck
Creating a mask frame???
woodchuck
- motherboard: PEGATRON Corporation 2AC31.04
- processor: 2.80 gigahertz Intel Core i7-2600S
- ram: 8.2 gb
- Video Card: AMD Radeon HD 6550A
- sound_card: AMD HD Audio
- Hard_Drive_Capacity: 1 Tb
- Monitor/Display Make & Model: Generic PnP Monitor
Hi Woodchuck,
There are numerous PSP tutorials to be found. A Google Search revealed these possiblities: PSP Mask Frames Tutorials Results.
The center of the Mask Frame should be either transparent or a color like green that is used for chroma-keying out. The Mask Frame can be and should be saved to a format that supports alpha channel (transparency), like PNG, TGA, or GIF. Insert the Mask Frame on a video track above the track with the image. VS should recognize the alpha channel, allowing your image to be seen through the center of the Frame.
Have a look at this page here and see if it helps you :-
http://mysite.wanadoo-members.co.uk/bri ... page1.html
I thought WoodChuck's question was more, once you have a transparent mask; how do you use it without making it a separate overlay ( ie, in the attribute panel of the first overlay, instead of choosing Chromakey, use "overlay mask", but with a wider selection of masks¢X.
Question is where does UVS finds thiese maks and where to register them
UVS 10+, Sony Media center
André
Hi woodchuck
The images for the masks are here:-
C:\Program Files\Ulead Systems\Ulead VideoStudio 10\Samples\Image
The images use ¡¥index¡¦ as a colour mode and are in-fact Black and White images
Well they are greyscale images.
I do not know how to insert more masks but can replace the existing ones.
Using an image editor to create a new image using Greyscale. The B & W image can contain grey, the more white the more transparent.
Use Pal or Ntsc frame sizes.
When complete change the colour mode from Greyscale to Indexed.
This will over-write the existing Mask Frame.
It may be wise to make a copy of the original M01
Unfortunately the thumbnail stays the same shape, and does not represent the new frame, if I find a solution I will let you know.
Seems to work ok
Good luck Trevor
Seems to work ok
Good luck Trevor
