VS10+ Trial Version.
I cannot change the TV Standard in Project Properties from NTSC to PAL.
Is this a limitation of the Free Trial download?
Cannot change TV Standard from NTSC to PAL
WestbrookNH
- motherboard: Hewlett-Packard 1631 KBC Version 01.33
- processor: 2.30 gigahertz Intel Core i7-2820QM quad w HT
- ram: 8 GB
- Video Card: NVIDIA Quadro 2000M
- sound_card: NVIDIA High Definition Audio 4x
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: Generic PnP Monitor (15.7"vis)
WestbrookNH
- ram: 8 GB
WestbrookNH
- ram: 8 GB
OK, now I'm confused.BrianCee wrote:![]()
Not sure I understand that statement - PAL/NTSC are important in an mpeg as that is effectively what is burned to a disc and plays in your DVD player.
If I select Properties->Edit->Compression Tab and select MPEG-2, the "TV Standard" Drop List in the Properties->Edit->Ulead VideoStudio Tab, is grayed-out and CANNOT be changed.
In fact, no matter WHAT I select in the Compression Tab, the "TV Standard" Drop List is grayed-out and CANNOT be changed.
However, in the Compression Tab, I can select various NTSC an PAL formats, so I thought that they were mutually exclusive from MPEG. I realize now that these other formats are Disk formats.
So, is this a limitation of the Trial Version?
I don't know about the trial version - never used one at all
but under the 'Compression' tab against 'Media Type' in the full version I have the options 'PAL DVD' and ' NTSC DVD' if I change between those two all the properties for TV standard also change in all locations - does that not happen in the trial version ??
WestbrookNH
- ram: 8 GB
