Aspect Ratio Stuck at 16:9
WestbrookNH
motherboard: Hewlett-Packard 1631 KBC Version 01.33
processor: 2.30 gigahertz Intel Core i7-2820QM quad w HT
ram: 8 GB
Video Card: NVIDIA Quadro 2000M
sound_card: NVIDIA High Definition Audio 4x
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Generic PnP Monitor (15.7"vis)
Post by WestbrookNH »
The drop down list box for the aspect ratio is grayed out, so I cannot change the aspect ratio.
What am I doing wrong?
VS10+ Trial Version.
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 1920 x 1080, 29.97 fps
Frame-based
(MPEG-2), 16:9
Video data rate: Variable (Max. 25000 kbps)
Audio data rate: 256 kbps
WestbrookNH
ram: 8 GB
Well, when I dropped the resolution down to 720x480, I was able to change the aspect ratio back to 4:3.
Is this a limitation of the trial version?
Post by Trevor Andrew »
Hi WestbrookNH
No this is normal.
I have tried with the full verson and it reacts the same
By selecting a frame size above 720 x*** you are selecting a 16:9 format.
When using 720 x ***, Video Studio Uses Non Square pixel rendering to produce widescreen.
Using 1920 x 1080 appears to be square pixels.
Use a calculator to work out the aspect ratio.
add/edit:- your project from VS 7 are in 4:3, trying to use HD sizes will result in widescreen, this will inevitably bring other problems when fitting your slide show to the frame.
Hope this helps
Trevor
WestbrookNH
ram: 8 GB
Thanks, Trevor.
I thought it was just me.
I created a small 1920x1280 MPEG file for a test, but the photos did not fill the screen.
I wouldn't mind the 16:9 ratio if I could get a full screen.
Is this just a Ulead problem?
Do other Video Editors have this same limitation?
maddrummer3301
Post by maddrummer3301 »
Last edited by maddrummer3301 on Fri Feb 02, 2007 11:20 pm, edited 1 time in total.
WestbrookNH
ram: 8 GB
Thanks!
Great tips!
But Nobody we know has HDTV, not here, not in Brazil, and not in Italy.
I was able to render the HD MPEG file, and it looked GREAT, but the photos did not fill the screen, so I went back to 720x480.
Not as good as the HD file, but good enough for a family slide show.
maddrummer3301
