hi all
i am having a problem,, when i try to capture in avi format it says cannot render streaming video, all i can seem to capture in is mp4 and the finished video looks awfull, my pc is a dual core 3.2 ghz, 2gig ram so i it should be able to do better , please help anyone as i am trying to save my mothers old vhs tapes
capture problem
We need more info from you. Have a look at http://phpbb.ulead.com.tw/EN/viewtopic.php?t=27 and http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Jeff
Dentler's Dog Training, LLC
nkdriff
re capture problem
hi black lab
i am trying to capture in the best qaulity format possible, if i try and set the capture format to avi once i start the capture it says "cannot render streaming video" if i capture in mpeg 2 i dont get full screen , the only one which seems to work is mp4 format but once burned to disc its blocky.
hope this sound clearer
Neil
Neil
Do you follow the Recommended Procedure as outlined in the first link?Black Lab wrote:We need more info from you. Have a look at http://phpbb.ulead.com.tw/EN/viewtopic.php?t=27 and http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8959
Please supply the requested info as outlined in the second link.
Jeff
nkdriff
capture problem
yes
SUBJECT: Please use a subject that describes your exact problem instead of making us guess what's in your post.
Nature of the problem
-cannot capture in avi format
Properties of your source files (format, file size, where did you get it?)
What devices are involved and their mode of connection?
- camcorder, composite
Project Settings
as specified in the tutorial
Output format (file, DVD, VCD, SVCD)
- dvd
PAL or NTSC
- pal
Error Codes (if any)
- cannot render streaming video
system info updated
Project Settings
- dvd
PAL or NTSC
- pal
system info updated
What kind of camcorder is it?
Jeff
nkdriff
With the Sony Mini DV you should be able to capture via firewire, which is really just a transfer, to your pc. Do you have a firecard installed on your pc? If not, they are cheap and a snap to install. Could be your relief to many headaches.
Also, some Sony models have a "pass-thru" option which will digitize an anolog capture (from your VCR) as it passes thru your camcorder (via firewire). Again, could solve your problems.
See this similar post http://phpbb.ulead.com.tw/EN/viewtopic.php?t=19433
Jeff
