Owned VideoStudio 10 Plus for all of three days......
I very quickly edited Xmas and New Year material but as you can probably imagine have had no end of issues burning it all to DVD. Having found this forum pretty quickly, I was able to read a lot of info and of course found that I was doing all the things I wasn't supposed to....
Anyway, I reckon I've cracked it (shouldn't have said that.....), but would appreciate anyone following my ramblings and seeing if there's anything i've missed or whether there is still anything I'm doing drastically wrong.
1) Camera I'm using is a new Sony Hard Disc camera. I download the movie files direct to my PC hard drive, so the need for direct video capture in Video Studio is not required.
2) I'm using a PAL template, 25fps and my project properties are set to this
3) I render each movie into an MPEG-2 file again using the Pal DVD template at 25fps
4) I then clear the project from the main menu - ie, nothing in timeline
5) Open create disc, and import the Mpeg-2 files I've rendered and create the DVD menus.
6) Burn to DVD
My previous 11 attempts had the following main 2 problems:
1) Disc burn failure (can't remember error message)
2) Choppy video playback on DVD player using DVD just burned. Zoom in's were ok, but panning left and right was choppy - unwatchable.
The daft thing is - on the 12th attempt, which yielded my first perfect disc, I had an error message saying that the DVD burn had failed. Well, I checked the disc and it had something burnt on it - a perfect copy with no jerky panning.
Have I cracked it??
One final question - all the titles and menus I find in the library are 29fps with a Microsoft AVI template - ok to mix these with my movie files which are MPEG-2 25fps jobbies? Or do I have to somehow convert the other Ulead library content first?
Wow - gone on a bit.....Sorry!!!
