I experience size/space limitation when I try to burn a DVD out of a VSP project(12 GB) using create disc (DVD-R of 4.70 GB).
Is it possible to accomodate such a project on DVD by setting/configuring something?
vsp vs. DVD size
You've not given much information for anyone to go on!
Even at the highest available bitrate, DVD compliant mpeg2 video runs to about 4.5Gb per hour of footage. I trust you are not trying to make a 3 hour long single layer DVD!
What are the file properties of your output?
Happy New Year!
Happy New Year!
htchien
You can wait for the HD DVD burner (or the Blu-ray burner). Once you get them, you can burn about 25 GB video onto the HD DVD (or BD).
However, it's still expensive to get those HD / BD burners (and media).
If you do not wish to get those HD / BD burners, then you are limited in 4.3GB (single layer) / 7.9GB (dual layer).
H.T.
H.T.
Ted (H.T.)
First tell us what format the video in your project consists of -- right click on one of the video files within Video Studio and copy down its properties here.
If it is 12 GB of DV/AVI format, then you should first render it to a DVD-compliant mpeg-2. Share > Create Video File > DVD. You don' tell us if you are in a PAL or NTSC country nor whether you are dealing with widescreen 16:9 or normal 4:3 video. But choose an appropriate template such as PAL (or NTSC) DVD 4:3 (or 16:9 which by default uses the highest bitrate setting and LPCM audio. That produce an mpeg-2 which is less than 4 GB and so, with a menu, should easily burn on a single layer DVD at the highest quality.
