DVD burn takes 2 hours, and smart render takes length of vid
parkerjd
I'm importing VHS and burning DVDs via ADS DVD Xpress DX2
Procedure:
capture from VCR with Capture Wizard 3.8
edit/burn with VS 9 SE DVD
I followed this forum's recommended procedure, and the Create Video step takes the length of the video (abour 1.5 hours), burning takes 2 hours (at 4x, but the Creating Video title part takes most of the time)
I may have a clue as to why. When it asks to match project and capture properties here is the detail:
Project Properties (prior to adjusting quality to 100% etc)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
Video Properties (from CaptWiz)
MPEG files
Frame-based
(DVD-NTSC), 4:3
Audio data rate: 224 kbps
Notice the Frame-based for CaptWiz? I want to use Upper Field first since I'm doing VHS-DVD, but I think since CaptWiz is doing Frame based, when I change project to UpperFieldFirst, this is causing the slow burning (2 hour) and rendering to MPG (1.5 hours). I am capturing to MPG anyways, but since i want to add titles, the recommended procedure says to Create Video to MPG before burning.
How much quality would suffer from using Fram- based setting in VS9, and would that speed my burning/rendering up?
Also, when I click Option before doing the burn, I don't have any settings described in the tutorial. Only a check box to "add personal files", and 2 other options. No settings for quality or lowerfield first,etc... Thought that might cause mismatched properties too.
Thanks for your help,
David
Procedure:
MPEG files
Lower Field First
(DVD-NTSC), 4:3
MPEG files
Frame-based
(DVD-NTSC), 4:3
David
Re: DVD burn takes 2 hours, and smart render takes length of
Hi David, welcome to the forum!
In order to produce a DVD with the maximum possible image quality, you should aim to minimise re-encoding the video. To that end, you should try to capture at the same properties that you wish to use for oputput to the DVD. In your case, apart from messing up the field order settings, you've used a variable bitrate of 8000kbps throughout.
Most users report that there is little point in using bitrates more than 6000kbps for VHS capture, so unless you are looking to fit not much more than an hour of footage onto a single layer 4.5Gb disc, there's little point in using 8000kbps.
Your workflow should be as follows:
1) Capture from VCR using upper field first 6000/8000 kbps
2) Insert your clips into a new VS9 project file. When you do this, you should be presented with a dialogue box which says Do you want to change the project settings to match the video's properties so VideoStudio can perform SmartRender? to which you should click "yes". Do all your edits, titles etc, then use Share>>Create video file to make a single mpg2 video file from your project.
3) Insert the video file into a new blank project.
4) Go to the Share>>Create Disc step. You can check the output properties by clicking on the cogwheel button.
5) Click on the "next" button to set the menu templates, chapter points, and so on.
Good luck!
I presume that you are using the ADS DVD Xpress DX2 to capture the VHS footage - and not using it for anything else.parkerjd wrote:I'm importing VHS and burning DVDs via ADS DVD Xpress DX2
Depending on what overlays, filters, effects and transitions you are applying, and the speed of your pc, 1.5 hours might be reasonable. However, if you are not making extensive use of filters and overlays, it should probably take less - but only if you can set the project properties appropriately. This might depend on what capture file properties you can set.parkerjd wrote:Procedure:
This is too long - following the recommended procedure, the previously created single mpg video file of your project should "smart render" in only a few minutes. It will take a few minutes to process your menus, but aftetr that, a single layer disk will burn in about 15 minutes at 4x or half that at 8x etc.parkerjd wrote:burning takes 2 hours (at 4x, but the Creating Video title part takes most of the time)
For video from an analogue source, such as your vcr, you should be using upper field first. Otherwise, everything else is OK.parkerjd wrote:I may have a clue as to why. When it asks to match project and capture properties here is the detail:
MPEG files
Lower Field First
(DVD-NTSC), 4:3
You should capture to upper field first, not frame based. Strictly speaking, MPEG audio is not part of the NTSC standard, but I've yet to experience any problems with it.parkerjd wrote:Video Properties (from CaptWiz)
MPEG files
Frame-based
(DVD-NTSC), 4:3
Can you not set the capture wizard to give you upper field first capture?parkerjd wrote:Notice the Frame-based for CaptWiz? I want to use Upper Field first since I'm doing VHS-DVD, but I think since CaptWiz is doing Frame based, when I change project to UpperFieldFirst, this is causing the slow burning (2 hour) and rendering to MPG (1.5 hours). I am capturing to MPG anyways, but since i want to add titles, the recommended procedure says to Create Video to MPG before burning.
Frame based is used for playback on progressive scan devices - eg a pc monitor. Regular TV's always used to be interlaced, but more recent TV's are progressive scan, and most standalone DVD players are progressive scan capable too. You could use frame based video for your DVD, so long as you don't intend to play it or have others play it to a non-progessive scan TV.parkerjd wrote:How much quality would suffer from using Fram- based setting in VS9, and would that speed my burning/rendering up?
You might be referring to the bottom left button in the "Create Disc" dialogue box. This is the Settings and options button. you need to click on the "cogwheel" button to the right of it, which is the Project settings button. This gives you access to the output video file properties.parkerjd wrote:Also, when I click Option before doing the burn, I don't have any settings described in the tutorial. Only a check box to "add personal files", and 2 other options. No settings for quality or lowerfield first,etc... Thought that might cause mismatched properties too.
Good luck!
jchunter
parkerjd
Thanks for your response 2Dogs
Thank you very much, I found the Options/Setting button under the Create Video dialogue.
I am going to upgrade to a later version of CaptWiz, because as of now I don't see any option to change to UpperFieldFirst, or to 6000kbps.
I will update any findings there.
jchunter
parkerjd
Recommend capture with VS 9?
Just curious, would anyone recommend capturing with VS 9? I just figured there was a reason they provided CaptWiz along side it
parkerjd
Darn that back button to heck
Any CapWiz users out there who have changed to Upper Field First for capturing VHS? I would think this to be a common issue, but ADS websupport has nothing..guess there are alot of people making inferior quality DVD.
Regarding the Smart Render taking a long time. I notice the preview window is playing along (I think at the actual rate of conversion from what I can tell). This would seem to be a big waste of resources, can I disable the preview during Create Video phase? I thought that Scene Splitter was slow (about 1/3 of the video length), this seems to be 1:1 ratio to the length.
parkerjd
Question
Someone correct me if I'm wrong:
If the goal is to minimize the number of renderings, then would this be ok?
Since I can't presently modify CapWiz from Frame-based, I should keep the project settings exactly as is until I am going to burn. In other words, don't change to UpperFieldFirst in the Create Video phase, but change it when I'm setting the Burn properties?
I'm assuming the same thing does apply to the 8000kbps being changed to 6000 kbps.
I'm assuming that doesn't apply to the quality 100% slider since you can't recover quality already lost.
The quest for quality continues
parkerjd
update
Burn options being modified decreased DVD burn time to 25 minutes
I can deal with the rendering, even though I'm considering using Frame based @ 6000 kbps since our TV has progressive scan.
The upperfield first is for capturing from VCR, but what about viewing on DVD....seems like you would want to change it back to frame based?
HAPPY NEW YEAR!!!
HAPPY NEW YEAR!!!
heinz-oz
parkerjd
Forgive my dumbness heinz-oz
so should i change it to upper field first for edit/burn (I don't have a choice for capture with CapWiz), or leave it as Frame based?
