Nature of the problem Capturing video from analog using USB and hardware device, the video sometimes "stutters". This means the frame freezes for milli-seconds, seconds or longer and the action is lost. For converting my taichi tapes, this is a disaster, the displayed motion and movements are lost.
Usually the first capture is ok and then it starts to "act up". For another tape it was always a problem and then suddenly once it worked! I haven't absoutely figured out a pattern or cause.
Playback shows the frames (motion ) was lost on the capture not just the display utility. sometimes it is ok , sometimes it is not. I have had to re-install over and over again because i don't know what causes this problem. restart doesn't fix, but sometimes unplugging and replugging and works, it seems sporadic, no fast rule i can see.
My same question posted elsewhere:
Will a new graphics card fix this or is it just a waste of money?I have dvdXpressDx2 andwith ulead and capwiz. I have some problems on the capture. The ulead studio editing works ok.
The caputure sometimes works , but after a few captures it starts to "stutter" By stuttering, I mean the frames start to freeze and one image remains on the screen and the others are lost for a few seconds or for a long time, so basically the video capture is toast.
The only way I can resolve this is that i uninstall and re-install everything capwiz, ulead etc.
There must be something simple that i am missing like setting a switch somewhere but i have tried everything and nothing works. I try to capture at the highest quality. but the stutter happens no mater how i set it but something must cause directly this becaue for instance i just did two perfect captures form vhs, then when i tried the third one the stutter ing was there and remained , i tried rebooting and deleting temporary files but that didn't help. I'm gettin tired of uninstalling and re-installing.
What causes this stutter and how can i fix it.?
Properties of your source files (format, file size, where did you get it?)
Capturing from Analog VCR recorders both VHS and BETA formats.
What devices are involved and their mode of connection?
Project Settings I use capture to best quality, but when the problem starts catrure to any qwuality has the same problem. My question is "where are the project settings that can correct this".
Since it sometimes works , sometimes doesn't I have the feeling that there is a setting somewhere, either that or some tempory files which need to be deleted (i of coures cleanded up my system including truning off firewall and popup blocker: all to no avail)
Output format (file, DVD, VCD, SVCD) : capturing to hard disk usually avi of mpg.
PAL or NTSC : NTSC
Error Codes NA
Another Question
Where can i find a detailed manual that can explainn all the settings in the control panels? eg frames etc what the settings do and more about their meaning.
EDIT: I just found the 9MB pdf for ulead sudio 9, but I have yet to check iit out for how much detail it has.
