Have DVD keep replaying itself...
nokose
Post by nokose »
I am currently working with VS 10 on a project and need to have hte DVD keep playing itself over and over again without setting it up on the player to repeat the disc (easier to have someone put the disc in and push play, rather than sit on the phone and try to firgure out a DVD player without seeing it). Also if this can be setup without having a menu displayed it would be helpful. Thank you in advance for any support you can give me.
Post by BrianCee »
You do not have to have a menu at all - after you have clicked on "Share >> Create Disc" in the new window which opens untick the box next to "Create Menu" , Also in that same window click on the little cog wheel at the bottom and put a tick in the box against "Auto repeat when disc playback ends" - you should then have what you require.
GeorgeW
Post by GeorgeW »
BrianCee wrote:You do not have to have a menu at all - after you have clicked on "Share >> Create Disc" in the new window which opens untick the box next to "Create Menu" , Also in that same window click on the little cog wheel at the bottom and put a tick in the box against "Auto repeat when disc playback ends" - you should then have what you require.
Unfortunately, the looping does not work when you do not have a menu (as we discovered a few days ago in the MovieFactory forum). This is a bug in the code, and needs to be fixed (imho).
On the bright side, if you create a menu, pressing play once should loop your video (if you do as Brian suggested and click the "Auto repeat..." option).
George
nokose
Post by nokose »
George
Ok so is there a way to have the menu only last for a second or two then autorun the program instead of having to select it?
GeorgeW
Post by GeorgeW »
Unfortunately, VideoStudio does not offer a menu-timeout function like other SD DVD Authoring packages (such as DVD Workshop).
You could Author your dvd to folders on your hard drive, then post-edit using tools such as IFOedit and PGCedit (but be careful editing the DVD as the wrong setting could stop the DVD from properly playing).
George
Post by Black Lab »
Does anyone know if this was fixed in the most recent SP?
GeorgeW
Post by GeorgeW »
I installed the most recent SP1 (from a few days ago), but it did not resolve this issue.
George
Post by Black Lab »
Thank you.
adjack
Getting VS10 to create an Auto Looping title
Post by adjack »
I, too, am trying to produce video from VS10 to loop endlessly on a standard consumer grade DVD player without any menu activation or other user interaction once the DVD player is powered up. I've read many suggestions here and tried several without using any other software.
Has anyone found any progress in this matter with VS10 or its upgrade?
Thank you in advance for your efforts.
Jack
GeorgeW
Post by GeorgeW »
The bad news is I have not seen a fix for VideoStudio 10 :(
The good news is this works now in VideoStudio 11 :)
There are tools that will let you modify the DVD Navigation to auto-repeat (like IFOedit or PGCedit).
George
adjack
Post by adjack »
Thank you, George.
I had just bought the VS10 upgrade from VS9 and have been struggling with this. Throw more money at it, right?
Post by Black Lab »
Yeah. 8)
adjack
Post by adjack »
George -
Before I upgrade to 11, have you been able to produce the looping with ease or to we have to jump through hoops to get it to work?
Thank you,
GeorgeW
Post by GeorgeW »
adjack wrote:George -
Thank you,
It was done very easily (imho). but I would recommend you download the TRIAL to confirm it does what you want...
George
adjack
Post by adjack »
Thank you. I'll take your suggestion.
