No Sound on OUTPUT to file
jmorgie
Post by jmorgie »
been using VS 9 for long time, good results.
Now ...
I captured from my Sony DV and that AVI file is just fine. I made a few edits, then went to Share and selected output to file. First tried AVI output, picture is great but no sound. If I save to WMF I get pic and sound. But if I save to MPG file, great pic but no sound.
any thoughts ??
What is the input audio? What exactly is your version of VS9 -- is it an SE? If so, and if your original audio is Dolby AC-3, the SE versions cannot handle it for licensing reasons.
jmorgie
More
Post by jmorgie »
Hi Ken, thanks for the help.
VS 9.00.1000, and no not SE.
re sound -- not sure how to answer. its a sony camcorder. I input the video via FireWire and the base file has fine sound. The problem comes when I try to output to a file. then I do Share, Create Video File. I tried NTSC DV[4:3] and there is no sound in the output [I played back with 3 different programs: Windows media player, Real, ATI file player]. so its not my playback.
I tried 'same as project settings' and also tried Mpeg2 NTSC. no audio in the OUTPUT of those either. Tried WMV 320X240 and that one DOES have sound playing.
I have used VS like 10 or 15 times in the past without a problem; then again this may[?] be the first time since I rebuilt my system 6 months ago.
Any thoughts ??
jmorgie
more more
Post by jmorgie »
more re audio:
here's the file for the AVI maker
Microsoft AVI files
24 Bits, 720 x 480, 4:3, 29.97 fps
Lower Field First
DV Video Encoder -- type 1
DV Audio -- NTSC, 32.000 kHz, 12 Bit, Stereo
jmorgie
more more more
Post by jmorgie »
Ken,
I was playing around; changed the audio encoding on the output to 16bit, 44KHz. Now I have sound. What do you think ?
I wouldn't have thought that would have created your problem as VS regularly deals with 12 bit input. On the other hand, though, I would not use 12 bit audio. You will find that is a camera setting -- look at your Sony manual. You change the setting to 16 bit so that all your future video is shot using 16 bit audio.
