Thanks for the responses, although "Black Lab" seems to have missed my point:
I have to ask this question of the posters on this thread. Why is it you didn't follow the RC before posting your problem?
Well, once I found this forum I did read the recommended procedure plus this thread and, yes, it fixed my problem. I only posted because I thought I had some additional detail to add eg I was editing DV, not MPEG as in Gary's case.
Let me start by saying I think it is a safe assumption that most users don't have a problem following the procedure in the manual.
I wonder if this is true, or if many are just not noticing? It was only in my latest DVD (2nd with VS10+) which has several fast pans etc that I noticed jerky video. Going back to the earlier DVD I can now see it there too. And, as with Gary, VS9 did not give this problem. So I tried an experiment as I still have VS9SE installed:
New project; insert short clip; record properties; go straight to share/create disc; check properties. In both cases the project properties after inserting the clip are:
PAL (25fps)
Microsoft AVI files
24 bits, 720x576, 4:3, 25 fps
Lower Field First
DV Video Encoder Type 1
VS9SE: in creat disc the "
Preferences" window reports
TV System PAL
Project Settings reports:
MPEG files
Lower Field First
(DVD-PAL), 4:3
etc
VS10+: in creat disc the "
TV System NTSC
MPEG files
24 bits, 720x480, 4:3, 29.97 fps
Frame-based
(DVD-NTSC), 4:3
etc
Several posters have indeed commented that video studio defaults to incorrect properties (jchunter for one), but in my case at least VS9 is behaving correctly and VS10 is not.
Well I now know how to avoid the problem so it's not a huge deal, but I made a word doc with screen captures etc and will send in to Ulead & see if they respond
Cheers,
Richard
