ulead8
BENDERSKY
ulead8
Post by BENDERSKY »
hi.
i am using ulead video studio8 and i am looking for more video filters and Transition Effect if someone know where to get some pls help me.
and something else i made a dvd disk with picturre slide show but a regular dvd dosn`t see it only div`x dvd and when i see it on the div`x dvd he made the picture smaller and i don`t see the adges.
pls help me if you can.
Please view:
Links to FREE stuff
I answered your other post relating to your slideshow which should also deal with the divx issue.
BENDERSKY
Post by BENDERSKY »
hi steve by the colculator i need to set the bit rate to 9570 but ulead doesn`t let me to do it he said that the max is 8264.
and there is no any free stuff in the link you gave me, it`s only help is some topics.
Here's the link to the free stuff:
This can be found in our Ulead Products Tutorials Section, in the Free Stuff for Ulead Products Forum.
Or you can scroll down to the bottom of that page and find a list of Links to Freebies
GeorgeW
Re: ulead8
Post by GeorgeW »
BENDERSKY wrote:i made a dvd disk with picturre slide show but a regular dvd dosn`t see it only div`x dvd and when i see it on the div`x dvd he made the picture smaller and i don`t see the adges.
You don't see the edges because of something called "Overscan". Basically, what you see on your computer monitor will not be what you see on your TV screen (you will lose ~10 - 20% around the outer edges (this Overscan area can vary from TV to TV -- it is still on your DVD, you just cannot see it -- think of it like a picture frame with an opening of 3.75"x5.75" on top of a 4x6 picture).
BENDERSKY wrote:hi steve by the colculator i need to set the bit rate to 9570 but ulead doesn`t let me to do it he said that the max is 8264.
That is because you are using Stereo LPCM Audio (which is 1,536kbps). The max bitrate for the Video/Audio on a DVD is 9,800kbps, so 9,800 minus 1,536 = 8,264kbps.
For a slideshow, I would use 6,000kbps (you shouldn't max out the bitrate because higher bitrates on the home-made stuff can cause playback issues on alot of DVD Players). Your version of VS8 might not have DolbyDigital audio (AC3), so you might be stuck with LPCM audio. NOTE: you could try mpeg audio at 224kbps (mpeg audio is ok for PAL DVD's, and on most NTSC DVD Players. But because it is not part of the NTSC Standard, some NTSC DVD Players will not play mpeg audio).
George
