I want to make a DVD from an avi file. The avi attributes is the following:
video: 720x576, PICVideo M-JPEG 3, 24bits
audio: 16bit, stereo, PCM, 48kHz
The project setting in the Moviefactory 3 is the following:
MPEG files
24 Bits, 720 x 576, 25 fps
(DVD-PAL), 4:3
Video data rate: Variable (Max. 4600 kbps)
Audio data rate: 224 kbps
When I start the output button, the MF3 will convert the file to 7000 kbps instead of 4600 kbps.
I don't understand why!
I have made a test with an another avi with the following attributes:
video: 352x576, PICVideo M-JPEG 3, 24bits
The MF3 project setting was the same as above and the MF3 has converted the avi to the 4600 kbps!
I think there is a bug in MF3
Regards
