I have several hundred slides of family that are sorted by number so that they reflect chronology. Problem: Using Windows XP they sort as intended but when transfered to Ulead the sort changes -
Ulead
100
200
On the "1 Organize" UI you can try the "Auto Arrange" button and see if you can get the sort order you want. If that doesn't do the trick you'll have to drag your slides to the desired positions manually.
